Some history. I had an Archer antenna in the wingtip and was only able to achieve 35 nm range. I abandoned the antenna and added cat whiskers on the bottom of the aircraft (beneath the horizontal stab) with a balun manufactured from instructions found on the Aeroelectric website. With the new antenna, I was able to achieve very good performance of up to and beyond 80 nm. Recently, I have noticed substantially decreased performance (20-30 nm max). The last time I had good performance was on an ILS approach into Newport, OR, last summer. This also happened to coincide with a changeout of my magneto to a PMAG. I recently inspected the location where the antenna is attached to the fuse and I found some stray aluminum spirals that may have been "shorting" between the two antenna wire connection studs. I vacuumed out the area and did a quick check of performance. When it appeared to be better, I though I solved the problem but probably didn't test extensively enough as I am still receiving only marginal performance. I bypassed the diplexer (providing the GS/VOR outputs) and connected the coax directly to the VOR connection on the back of the 430W. I now receive signal up to 40-50 nm, but no more. Help me decipher my troubleshooting efforts and suggest further troubleshooting or solutions. Thanks!
