RONSIM
SOLVED:!! (but not understood) I started getting "High Amp" alarms on my Dynon EMS 120 when I used the "push-to-talk" on my Narco Nav/Comm. Thinking it was stray RF, or something, I started looking in that direction. This morning, I used a clamp-on DC Ammeter to measure current pulled from the battery by my various systems --- everything as expected until I did the "transmit" on the Nav/Comm --- measuring on the down-stream side of the circuit breaker, I was showing 12-16 Amps (5 Amp breaker did not trip on the momentary transmit) ---
The Nav/Comm receives and transmits normally ---- I am assuming I have something going on in the transmitter ---- any ideas?.
Solved this immediate issue by switching the Comm antenna coax out of the Narco to a Comm antenna I installed on the bottom of the airplane for my handheld radio. Connected with a length of RG58 and a coupler. Everything back to normal and Navcomm pulls about 3.5 - 4.0 Amps.
When I get a chance, I will try to track down the original coax/antenna issue and do some more "experimenting" and look into the 5 amp breaker issue!
I appreciate all the help I have received and some of the suggestions on wiring I intend to implement at the next chance.
Ron
Ron
