More builders seem to be using the Napa 7220 self-etch primer. I would like to hear from you regarding how you have prepared the the primer for the final top coat on your interior surfaces.
Are you placing a final coat on each piece soon after the primer? What are you using?
If it is months (or years) later - what are you doing to remove oils, ect, before the final coat?
