BlackhawkSP
Guys:
I have the 2 NACA vents to install on the front fuselage and 2 others aft of the baggage door on each side to feed the Aerosport overhead plenum. The drawings say to simply use Pro Seal to bond them to the inside of the fuselage. Is the Pro Seal alone sufficient to keep them on, or have others also added a rivet or two as a mechanical backup fastener? Just wondering.
