Gentleman:
And each of you...
Stephen
Pierre
Pat
Robert
Jim
Brant
Starkey... where are you, neighbor ! ... actually, Mike is the first on this list to have seen this plane in my hangar... some weeks ago. I expect he has been wondering where the heck I have been as I joined this list and not posted anything in weeks since... so Mike and I were at the same Christmas party for Cameron (O61), but were too busy to chat RV stuff...
I am jazzed by the replies from you all and have already learned a lot and confirmed much of what I heard. It is clear that I have the great fortune to now have Brad's fine creation. You all have confirmed what my eye has observed... that of a special aircraft. I will treat her well and with respect.
So, on with some details...
Yes, Jim. I believe Brad built up a 320 with a front prop gov. The cowling that he and Rocky must have created together is a fine piece of craftsmanship. The intake is now ducted from the top of the engine and has a K&N filter fitted. His original engine was from a Warrior and I see he must have put some 500+ hours on that engine in this plane. In 84 he re-certified the plane as an A. I have that on the data plate and the AC. I scoped the inboard wing ribs and the doubler plates are there. I do believe it is an A.
Pat said that Brad put the engine and prop together, ground ran it and never flew it. Pat said he put the first 20 or so hours on that engine, flew it up to Dalleske twice. Once to show it and then to deliver it. Dalleske did some Formula 1 flying at Reno, in a Cassutt. Did not put much time on the 3... maybe some 50 or 60 hours in the 10 years he owned it.
Yes, I do believe the plane was not painted till Dalleske had that done in Salinas back in 95 or 96. It is now Orange and White.
Brad had a fuel delivery system that puzzled me. Line went from the selector, which I will change to a new unit, to the firewall, to the gascolator, to a T fitting ( that then provided a second feed to the carb ), to the electric pump, then to the mechanical pump then to the carb. The carb had two inlets. On my first engine run, that fitting failed out came fuel for a moment till I cut the engine. I have since abandoned that second fuel line. Capped off the T, removed the second line to the carb and now have one linear fuel line to the carb. Its temporary... I will install a flex line from the mechanical pump to the carb before I fly the plane. Unsure why the dual feed... maybe to prohibit vapor lock at altitude?
To get to the fuel selector to R&R, we had to remove the tank. We can now replace the fuel and brake lines.. good.
I plan on replacing the old EGT and CHT. Moving some things around like the start switch, and maybe install a D-10a that I have. Will see.
I will post this, and try to attach some pictures... but I am not an IT guy. So, if I can't get pix attached, will take up Brant's offer to send them to him and he will post.
Lastly, I am new here, and do not want to trip on my shoe laces. The plane I have been flying for years.. a real flying project is N46CJ, a Chinese Nanchang. So, my buddy Randy Thorne has been a resource for me..he had a RV4.. and has worked on my CJ6 a lot years ago. He could never figure out why I stayed with the Cj and not get an RV years earlier... I must be a laggard, go figure.
Ok, enough for now. Again, thanks for all your info and interest. I do want to pick up the phone and chat with some of you...Jim especially. So, will soon.
Will post pics here, or through Brandt.
dn
And each of you...
Stephen
Pierre
Pat
Robert
Jim
Brant
dn
