I now have 9hrs on phase one. I had a heating issue on no.1 cylender. I kept thinking it was not seating on the rings, but when I pushed the plane it would heat up, as soon as I let up on it, it cooled down. Off came the cowl and pulled the injector for no.1, blew it out and reinstalled. All fixed. I had some electrical issues with the radio, blew out the cuttings from cutting the panal for the 696. Now I'm into doing my touch and go training. I have found that with the constant prop, I can keep it flat and use way low throttle, keep it at 2700rpm on take off 1/4 throttle, 80kts. She shoots off the runway, I pull power back and settle on 2500rpm. Good on the engine, still fresh, I fly the whole pattern at 100kts in down wind. I keep my pattern nice and close and short. I get cleared for an option, pull back on the throttle to 80kts, I dump the flaps, electric with switch in the stick, ray allen and the left right is flaps, the right is up. I than nose it to the gound into the base and slip it down as well, I maintain 80kts. I get to the base to final about 1000ft out and let it drop to 70kts. Now this is the trick that I found works real swift, first off I found that with full flaps setting on the runway, makes it real hard to keep the nose off, it wants to come down right after landing, even with the stick back all the way.
Now listen up, this is way cool. You have full flaps on, 60kts level just off the runway about 3ft off, than hit the flaps up, on my stick, with right hand on the throttle just in case. As you hit the up on the flaps, the nose flairs up and the airplane settle nicely on the runway. WAY COOL, and the nose stays up until the speed bleeds off and the nose will settle down. WAY COOL. You use the flaps to do your flair. No more slam down on the nose.
I was doing touch and goes by doing this and than maintaining speed and keeping the nose off for about 2000ft. than hit the throttle, remember the flaps are already up, and depart the runway and do it again.
This plane is fun fun fun.
