Tony Partain
1. Kit costs will be about half of the 7QB, the only difference is the fuselage and empennage construction. Now with the QB wings for the RV-3B this will shorten the time to finish.
2. Cost of engine. An IO320 will be less than an IO360 and it will burn less fuel. Bart I will be calling next fall!
3. Cost of panel. To build a RV-3B I will need fewer “expensive parts”. The panel on my 7 cost over $30,000, of course this was in 2005 and the same panel now would cost less due to the influx of glass EFIS manufacturers. I expect that the panel on the 3 will cost about half of the 7 panel. AFS 3500 Trutrak Digiflight VSII
4. This one is all about me! Build a nice plane and keep it that way.(My Kitfox is going to by my kicking around plane that I can throw my friends and stuff into and not worry about scratching or getting it dirty.) The 3 will be the “nice plane”. The one that when you park it, walk away and turn back to look at it again and think yes I did build it and it looks great and it’s mine!
5. Center line seating. I bought a flying RV4 in 1996. The flying qualities of that plane still stick in my mind. The 7 is a great plane but different. From what I've read, I believe that the 3 will recapture that feeling.
6. Right hand flying. I am left handed but always seem to fly the RV4 better with my right hand. Strange but true.
7. Construction. My first build was aluminum, the RV7. I am now building a Kitfox, tube and fabric. The Kitfox is much easier to construct. But every time I need to fabricate an aluminum piece it makes me smile. Time to get a pile of aluminum for a fix.
8. My Kitfox will cost less now. (All of the wives out there would love this one). The panel will be very basic now in the KF and not a robust glass panel. Steam gauges and simple. Just need a GPS, a hand held radio and go!
9. Vans. How can you go wrong with this company? You can’t. When it comes to kit companies they have set the standard. I know I’m preaching to the choir, but it’s true. As a transport company for the kit industry I have talked to every kit manufacturer out there and most do a very good job. There are a couple of small companies that do a fantastic job, but no one has the track record of Vans.
Now I have a problem. TWO PLANES UNDER CONSTRUCTION AT ONCE! Ya let the fun continue!
The RV-3B components list, so here is what I am doing so far.
Engine IO320 from Bart @ www.aerosportpower.com
Efis from Rob @ http://www.advanced-flight-systems.com/index.html
Digiflight VSII Auto pilot from Jim @ http://www.trutrakflightsystems.com/
Radios and harness from Stein @ www.steinair.com
I like to fly but this part of collecting and researching is the best part.
The tail kit is here and I am off to the hanger to play with my new toys!![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
