I found that not all low pressure fuel pumps are the same about a month ago. On the go from a low approach, my engine started running very rough and losing power. I pulled up and, while turning into the downwind, went through engine failure EPs. Changing tanks and turning on the boost pump solved the problem. Troubleshooting the problem after landing, I determined that my mechanical fuel pump had failed. This fuel pump was the Lycoming pump with the laminated arm, not on the SB for replacement. I ordered a newTempest AF 15472 channel arm model and installed it and it did not work. No pumping action whatsoever. Removing the pump and reinstalling, I did determined that the pump would pump residual fuel halfway across the hangar by hand actuation. But there was enough slack in the lever that, approximately .75". My fuel pump push rod extension was approximately the same, therefore the push rod extension maxed out before the pump lever began its pumping action. I called Tempest and explained my problem and the teck rep suggested I replace the channel lever pump, the new model, with a laminated lever pump, a discontinued model but still available as a rebuild only. See part 2.
