My kingdom for the location of VS-01402
PatMac
Active Member
Good morning. Checking inventory last night and came across VS-01402. Could not find on drawings... but Im sure it is there..
Thanks in advance.
Pat
Chapter 11, "VS-01402 VERTICAL STABILIZER BRACKET"
Edit: the PDF plans from Van's are highly worth the ~$10 - this bracket popped pretty quickly on a search.
Here!
Page 11-06 Shows it...
You can also do a global search in the WIKI
SHIFT-CTRL-F will get you the folder search on Adobe. Select the dropbox WIKI folder let er run. It will search all the documents in the WIKI for your item.
