Music input
Mr Charles
I have a Flightcom 403mc intercom, king ky197 comm, and a mono input jack for music input into the intercom. I have a Sony walkman mpeg player, and can hear the music, but barely! There is no volume to it, no matter the settings. I have plugged in another mpeg with same result. Is there anything out there to boost the output of the walkman, or is that even the problem?
Thanks for feedback
Charles
one option
The newer audio panels have increased the audio volume because of this issue. For the older panels, you need to increase the volume. There are several options, this is one you can consider.
http://www.boostaroo.com/
Lots of older threads on this, try a search, be sure to change the default setting for the search time period to "any date".
If you get to the search function by clicking the link at the top of a page, be sure to click "advanced search" option, when the window opens up.
Advanced search is a lot better way to go.
See if you have a "music gain" wire in your intercom. Connecting that will double the music volume.
