PilotBrent
Will be contacting Van's this week for direction on how to best handle, but was curious if anyone has had to deal with this before.
I have been running the engine, balancing carbs etc? as part of Production Acceptance Procedures and yesterday removed the lower cowl. Noticed that I have had some interference between the lower left front muffler spring and the cowl. The vibration has rubbed through both the heat shield and also into the fiberglass and has opened a small hold into the duct that goes to the radiator. May have occurred before the carbs were balanced and the vibration was much more prevalent at low RPM. Muffler itself is not moving when I try to shake it and I don't see any obvious leaks around pipes (have only minimally run the engine however). When installing the muffler I believed I had placed it in the correction position but maybe its a tad the the left to lead to this interference. Anyone else seen this before..
Regardless, will need to repair/patch.
![f1f8dd.jpg](/proxy.php?image=http%3A%2F%2Fi39.tinypic.com%2Ff1f8dd.jpg&hash=7dc11585423c8068453aef46f8fb9c12)
![2cwpf8l.jpg](/proxy.php?image=http%3A%2F%2Fi42.tinypic.com%2F2cwpf8l.jpg&hash=f3dfec34ee62f5d7f04e0b07d50666ad)
![2znzghj.jpg](/proxy.php?image=http%3A%2F%2Fi42.tinypic.com%2F2znzghj.jpg&hash=af239413ac65541876f74e697457b56f)
