MT 860- 4 issue /original post bout bleeding line
RVTOY
After a couple first run up on rebuilt motor and not able to get new prop to move I took it off the governor then put it on the bench and hooked up drill to the gear and spun it clockwise slowly while feeding it oil. PG Didn't want to do anything except spit up out of the wrong ports (yes ports). Turned in reverse but comes out oil inlet port. MT P860-4 for rear mount io360. Facing the pad the adapter gear turns clockwise. By the way PG has manufacturing date of March 2010.
What do you think?
