okay so the vans instructions have the MP line going off the right side to the firewall and I know that that is good if one is using the round gages, but if you are using an electric MP sender what have people done?
Run the line from the left side to the right and hooked it up to the block on the firewall or move the line to the left side and then to the block on the firewall?
thanks in advance for any and all input. Also if you had it to do again would you still run it the same way?
