Here's what I know so far:
* Barrett IO540 with 9:1 pistons and AFP 200 FI system built in 2009. Aero composite 3-bladed CS prop. Rod Bower ram air. 2 Bendix 1200 series mags that were newly overhauled at engine build. 185 hours tach time since new.
* At 150 hours hobbs time the number 1 cylinder was pulled and sent back to Barrett for "excess carbon build up". Barrett honed the cylinder and either lapped or ground the valves.
* The engine had a variation at idle of 150-200 RPM when I first flew it 6 month ago, but otherwise seemed to run fine and always made good power. Lately it's developed a miss at idle and during runup, with an occasional miss in cruise flight. The miss is not mag specific. The MP at 700-800 RPM idle is 14 inches.
* So far I have replaced all the plugs with Tempest fine wire plugs. I have cleaned the injectors and checked for equal fuel flow using the baby jar method. I have replaced all of the intake gaskets, top and bottom. 2 gaskets looked suspicious, like they may have been leaking.
The flares on some of the fuel lines in the tunnel looked imperfect, and these were either corrected or remade. The mechanical fuel pump was bypassed and the engine run with just the electric pump in case the mechanical bump was leaking air into the fuel system. I cleaned the sniffle valve and made sure the ball inside could move freely.
* After the fuel lines were corrected the engine was started cold and ran really bad, even after warming up some.
* So far I've had two A&P I/A mechanics help with the work and one person who used to work at AFP help check then FI system, but he didn't check the servo or flow divider as that has to be done on a flow bench at AFP.
Today I will either remove the sniffle valve and plug the opening or block it so no air can get in that way. I doubt that anything I do today will resolve the issues but I'll at least rule out one more thing. I will also verify the MP reading before engine start.
I will also video the engine page of the 900X and post it. I realize that there may be multiple issues such as an air leak, sticky valves, and a bad servo or flow divider. I don't have the experience to deal with the valve guides or FI system, but I'm open to suggestions.
This is a poor video that was done with he sniffle valve removed and blocked off.
https://youtu.be/zi-ZM-qn_Ao
regards
-Marc
