Ex Bonanza Bucko
The installation docs for the new. second, Skyview on the starboard (co pilot) side of the panel say to "relocate the voltage regular as per section 46."
Since I did not build my S-LSA I am not too good a reading Van's builders' manuals. But it appears to me in section 46 that all that is required to get this move made is to unbolt the voltage regulator from the rack in the engine compartment, unplug it and move it to the deck under the instrument panel using the main wiring harness hole that is available there.
If you have built an RV12 and understand the above please tell me if I have read this process correctly. I, of course, will have an A&P do the work or at least sign it off.....my son is one of those![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
EBB
EBB
