Lynnb
So I'm looking at mounting the steps and have read all about inserts, larger bolts and access panels. My main concern is keeping them tight, I've seen at least one plane where the steps have become loose. I was wondering what the group thought of just adding another screw or bolt off to the side that is tapped and threaded through the mount and step just to lock the step in place. I wouldn't drill all the way through. I am working on a QB so Van's has already drilled the main hole, might take it to AN4 as others have suggested as well, thoughts?
![20160430_122915.jpg](/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F--ztWIqoh1n8%2FVyTslSh8FcI%2FAAAAAAAAfJQ%2FSllRd6Nbn6Mm7HCIZiJNHq344c3YWVMEwCCo%2Fs1152%2F20160430_122915.jpg&hash=4197ffd817eea6f253de10847248f7c7)
