tomcostanza
So I have some radio trays (steel) to mount in the panel. I planned to use aluminum angle, riveted to the panel. The trays are dimpled, to accept flat head screws. That implies that the angles will need to be countersunk to accept the dimple. I don't think I can rivet the angles to the panel, and then put the trays in, because the dimples won't get past the angle. If I rivet the angles around the trays, I don't think I will ever be able to remove the trays without drilling out at least one of the angles.
Am I missing something? I could use screws to mount the angle(s), but I see from most builders' web sites that the angles are riveted to the panel.
Any thoughts?
Regards and thanks,
Any thoughts?
Regards and thanks,
