I'm pretty sure I already know the answer, but I thought that I would ask this question to confirm my thoughts: Is there any preferable position to install (i.e., "clock") the prop on the 912ULS? I know you can't "prop" a 912, so that isn't a positional factor. The reduction gearing means that you never really know what position the prop will stop at after shut-down. So, it appears that there is no "right" way to position ("clock") the prop during the install?
