You need the longeron to do anything that has a lip or flange. This one I use quite a bit too.
Not really true. Yeah, the longeron yoke is good for that, but not necessary.
For what it's worth, I used
this set in my 3 inch yoke and never, ever needed a longeron yoke. Yes, I riveted my longerons with that set too (most longeron rivets have to be bucked anyway because top skins overlap them).
Many old school builders have no idea what a longeron yoke even is.
I built my entire slow-build -7A with that one 3 inch yoke. The *only* yoke I think may have been nice was the no hole yokes for setting rivets near the trailing edges of the control surfaces. Those yokes are ~ $130.00. If you count the flaps, ailerons and elevators and rudder and assume you need the yoke to set the last two rivets on each side (8 rivets per control surface), that means the yoke costs you $2.32 a rivet. You could also easily just leave those rivets out until you find a yoke you can borrow and then just set all of them at one time.
What about those rivets you can't reach with the 3 inch squeezer? You may just have to break out the rivet gun and bucking bar.
![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Believe me, it won't kill you.
My recommendation is to start with the 3 inch yoke and you can always order the other ones.
