More Open Rivet Holes
yankee-flyer
Way back on Page 21-16 it says "Cleco but do not rivet the holes shown'- and the drawing has a box around four rows of six rivets on the aft end of the bottom skin. The rivets in each row get filled when the tailcone and fuselage get joined but I still have 20 open rivet holes. I'm misway through the finish kit and still haven't filled them. Did I miss something (I've searched) or is there still something to come that will be riveted there?
THANKS!
Wayne 120241
Hey Wayne
25-04, step 3 tells you to rivet all together. Those 4 rows should be done then also. They were left out so you could get the tail into position easier. Once you have it cleco'd into place, you can rivet all those on the bottom. Hope that helps.
John Bender
