Mark Henderson
Today was to be the first flight of N815W. As I taxied out to the runway the low fuel pressure alarm started going off. I had had an issue with this a few days ago, and thought it was resolved. I have verified that there is no blockage of any fuel line. The screen in the gascolator is clean. The fuel valve was fully open. Yesterday I had a consistent 3.3 psi of pressure. I parked the plane in the hanger for the night. I added 5 gal of fuel.
Today the pressure fluctuated between 1.5 and 2.7 PSI. Engine speed made no difference. The pressure would drop and the alarm would go off. After a few seconds the pressure would rise, then drop. In case it might be a blockage in the fuel vent, I had a friend pull the fuel cap off as I sat there. No change.
I taxied back to my hanger and pulled the top cowl. Nothing looked amiss. We disconnected the VA-216 fuel line from the sender and turned on the master. There was a good fuel flow, although I had no idea what the pressure was. After reconnecting the line I had 3.3 PSI with the engine running. After a short taxi it dropped to 2.7-2.8 PSI for no reason, then came back to 3.3 or so. There does not seem to be any rhyme or reason to the fluctuation. It was too late to find a mechanical fuel pressure gauge today. I have read other posts, and it sounds like it could be the Dynon sensor, or air in the line. I don't know why there would be air in the line after purging it 3 days ago.
Does anyone have any ideas?
