David Shelton
I noticed that a lot of builders are increasing their fuel capacity. I'm thinking about designing an aux fuel cell to put in our cargo pods. Since the pods are already designed to carry a motorcycle, they are properly ventillated and fitted with drainage grommets in the event of a fuel spill.
How many gallons do you think it should carry? The pod has a useful load of 250 pounds so we should be able to carry up to 40 gallons. I'm tempted to make it a little smaller to leave space for some luggage. How often do you guys need more fuel? Do you think it's better to replace the main fuel valve (use one that can select from 3 tanks) or plumb a bipass around the fuel valve with a seperate valve to control the aux tank?
-David
-David
