First off, I built my front seat and flap stops exactly according to the drawings. That was long before I had the wings in place so now I'm puzzled. When I bring the handle all the way up onto the top stop, the flap actuator weldment will have to pass through the floor a bit. Is this right? If I then set the pushrod length to achieve 42 degrees deflection, when I retract the flaps they are in trail before the handle gets to floor level. All in all, I'd say the drawing has the stop locations out of whack and that putting them in before getting everything else set was way too optimistic. I'm hoping that others can share what they did before I go out there and try to make it right.
Questions:
1. Should the actuator penetrate the floor to get full deflection?
2. Should the handle sit right on the floor when fully retracted?
3. The manual says 42-44 degrees full, but doesn't mention the intermediate setting. Anyone know?
Please don't be shy about giving lots of detail or even a pic or two . Thanks.
Questions:
