There seems to have been a lot of threads recently on various aspects of the doors which I have been reading with interest as I am just fitting mine now - once I got the garage up from -8C!! These gas space heaters are great
Strangely, it has all been going well so far, although I have only done the initial trim and fit. So my question is this: once the doors shells are glued together and you start to trim to fit the opening, is there an easy way? It seems you cannot scribe from the inside because the channel is in the way. Is it really just a case of door on and off twenty times as you take bits off here and there?
