s10sakota
In order to match drill all of the holes in the center section parts, the instructions indicate that I should insert two close tolerance bolts and cleco the parts together. Inserting the bolts insures accurate alignment.
So I opened the wing bolt bag and inserted two bolts. As you can see in the pic below, only the threaded portion of the bolts go into the holes.
In order to get the bolt in, it looks like I would have to tap it with a hammer. If I do this, I would bet that it would be a B*&^CH to get them back out!
So, do I have to insert the bolts all the way? Suggestions? Thank you-I really don't want to screw up these gold parts since they are all match drilled and built at the factory. Replacing them would be slightly expensive!
![](/proxy.php?image=http%3A%2F%2Fi108.photobucket.com%2Falbums%2Fn7%2Fmarky613%2Fbolts_zps6cbd3926.png&hash=3ee69a2ddae85c95624b3a9e37ff5d66)
