History and Update on project
Okay, now that Brian has been mentoring me on this project for a couple months, and I've been lurking around this forum for longer than that, I actually think I have enough knowledge to start asking some of my own questions and give some of my own project updates.
I'll give a little background for those who might be interested:
A best friend of mine, Rick Borgmann, got interested in flying in the early 90's. He got his PPL, went to Cheyenne AeroTech and got his A&P, and then got a job with Butler Aircraft in Bend Oregon as a mechanic, and eventually flew in the right seat of a DC-6 retardant bomber with our mutual friend, Del Hunt. Around the same time, Rick got real excited about RV's and purchased a partially started -4 from someone(whom I don't know). The number on the plans is 128, so it's kind of old. He worked on it for a number of years off and on. He basically got most of the surfaces done. Had the engine hung, partially baffled, no seals. Had a fair amount of the wiring done with mostly old steam gauges.
Brian and I have worked together at a hydroelectric plant for the past 20 years or so. Brian got interested in building an RV about 6 or 7 years ago. I introduced him to Rick and partially based on his conversations with Rick, Brian started building a -7. A year or two later, Rick died in a tragic manner at the hands of his own father in a murder/suicide. I knew that Rick loved the plane and wanted to fly it and I felt sentimental about it. So I bought it out of his estate with a personal pledge to myself that I would finish it and fly it in his memory. Although I consider myself a skilled hydro turbine mechanic, I've never known much about working on or fabricating airplanes. So the plane has been sitting in my shop for the last 5 years with me wondering what I got myself into. I've never been able to find any builders log. I've got the original plans which look sort of like Egyptian parchment. So I contacted Van's, sent them a copy of the legal document that conveyed the project to me, and they sent me a copy of the original plans along with a builders manual. Still didn't do me much good.
Fortunately, Brian learned quite a bit while he was building his -7. I visited with him at work a lot and followed his progress. And I'll be darned if he didn't finish it!!! I followed his progress through his first flight and testing phases and it was all pretty fun and exciting.
Anyway, I still didn't make any headway on this project. Just didn't even know where to start. But evidently, once an airplane builder-always an airplane builder. Because Brian started bugging me about finishing the -4. I think he just needed a "fix". So last November, I started by REALLY cleaning my shop out and organizing tools. Then in December, Brian and I scheduled a date to "look it over". Now it's "Katie bar the doors" and the rate that my brain is trying to absorb all the knowledge that is coming at me through this forum and directly from Brian?.well ?..it's sort of like trying to drink from a fire hose!!! At first I felt like an absolute idiot, but with patience, Brian gave me Riveting 101 and I started by drilling the rivets out of the wingtips and replacing them with nutplates. Slowly but surely, I'm inspecting every bit of the work that has been done and planning all the work that is left to be done. I really didn't realize that there was SO MUCH left to be done. But now I know enough to know THAT, which is good.
So here's the status as of today:
Brian and I started by focusing on the wings. My friend, Travis Elbert, who paints airplanes, has an open week in his shop and he owes me a favor so we wanted to take advantage of that.
We put the wings on the plane. Learned that Rick had already drilled the hole in the rear spare attach. Double checked everything with strings and plumb bobs. Not bad. Put the level and the block of wood on the wings and found that the wing had more incidence than called for. As I recall, with the siderails level, there was about a quarter inch of air between the block of wood and the level. So we worried about this for awhile and searched the forum and made some calls. Decided that the solution was to prop the tail up a little more(siderails no longer level) so the wing level sat on the block like it was supposed to. Then, we checked the HS like the plans say to. It was flying downward about 3/16"(if I recall correctly). We figure we will shim the leading edge of the HS so it is correct in relation to the wing. Then the fuselage will be slightly off from design optimum, but we think we'll be okay. If anyone wants to weigh in on this issue, we'd listen.
We cut the aileron pushrods to length and riveted the ends on.
We cut the weird holes for the flap actuating rods. I looked at the result in disbelief, but Brian reassured me that all RV's look like this. Besides, it's covered over when the flaps are up. BTW, because of the advice in this thread, I'm getting rid of the flap handle and installing electric.
We hauled the wings to the paint shop. Then, in the meantime, I decided to rip the steam gauges out and upgrade the panel. That means I needed to put in a pitot mast for the AOA probe. So I have a panel upgrade going already.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The pitot mast is SafeAir1. It was fantastically easy to retrofit to the wing through the existing inspection cover. The instructions were great. Since I couldn't find the instructions on the SafeAir1 website or the Avery website, I think I'll scan mine in and post them to the forum under the proper thread when I figure out how to do that next. They would be helpful to anyone considering the retrofit.
Now that the wings are gone, I'm on the fuselage full time and wishing I didn't have to go to work on Monday. I've ripped out the old panel, and basically all the wiring. I've got a fake seat installed in the cockpit and spend a lot of time sitting in it looking at everything and making airplane noises. Throughout the course of today, I came up with about a bazillion questions to ask Brian next time I get him over here.
I'm going to seriously look at the NACA duct under the wing for ventilation, and the taxi position latch for the canopy. So thank you guys for those tips! I'm pretty sure that I have the short landing gear so I will be doing more research to decide if I want to do anything about it. Probably not. Opinions welcome.
So now, for those of you who are still with me. I better ask at least one question:
We've decided to eliminate the heavy Concorde battery and cable from the luggage compartment in favor of a PC680 up front. I'm in love with the idea of locating it on the front of the firewall and have seen the discussion about heat, etc. I haven't seen anything to make me want to put it on the aft side of the firewall though. If anyone has heard anything definitive saying it shouldn't be inside the cowl, please let me know.
I think Brian was right when he told me the toughest and most time consuming thing about building airplanes is making decisions!!
Thanks for listening, and all the help so far. Hope I don't get kicked out of the forum for making such a lengthy intro!! The following posts will be shorter. I feel certain I'm going to get this older bird flying.
Mike
