It was late, I was tired and a little rushing, and a mistake was made. I forgot to rivet the inboard flap rib to skins before closing the spar. Now, I have to use pop rivets for entire inboard rib. I ran through some crude analysis and it seemed that the MK-319-BS rivets would be ok to use. Per web info, shear strength = 258 lbs, tensile strength = 298 lbs. The allowable is actually higher than these for AN426AD3 rivets. Just want to get options from the RV experts, is it really OK to use MK-319-BS here, other than the cosmetic reason? Or what is the suggested pop rivet with the equal strength to a solid rivet. I know there is always a gap between "theoretical" and "practical" answers. I am also waiting for "official" answer from Van's.
My quick but conservative calculation (link here) showed the rivet would see a shear force of about 105 lbs (Vfe=100 mph). And the analysis is very conservative in my opinion.
