Finishing my engine build which is an ECI IO360 with cold air induction but using the silver hawk (bendix) fuel inj system. According to the precision web they recommend Vans builders use the alternate rotation mixture configuration. this means the mixture shaft rotates counter clockwise from idle cut off to full rich when viewed from lever end. Im overthinking this and dreaming of FI systems. How can they make a statement covering all vans aircraft when some use levers (push on lever means pull on cable) and verneir (push=push). now Im completely befuddled as which to use. anyone have any good first hand knowledge please advise. keep is simple, my brain is full ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
