jdeas
I am replacing a custom control bracket on an older RV6-A with Van's VA-149-320-PC bracket due to some issues with securing the control cable end points. Installing the new bracket, the mixture control location comes back lower than expected and only a few inches from the from wheel structure. Does anyone have a photo or suggestions on the mixture cable routing for this combination?
Any photos or suggestions would be appreciated, the battery is mounted on the cabin floor and it appears I'll have to route very close to the center line and very low on the firewall to get a good angle on the cable.
The distance between the cable bracket mount and the mixture control arm also seems to be longer than standard.
