As per the e-mail I sent Van's
Hello Support
RV-14 , kit # 1400018.
As per your packing list you supplied 6 pcs of J channel 6 ft long and 4 pcs 8 ft long. For the wing box we are to cut two pcs 73 9/32" long. This will require cutting four 8 ft lengths (both wings). We are to cut two pcs 46 1/8" . All we now have left in stock is 6 ft pieces so four (both wings) need to be cut for the the wing box short j channels. The outboard leading edge requires two pcs 59 3/8" using up the last 6 ft lengths. We still require two pcs 54" long for fuel tanks.
I do believe the quantities on the 8 ft and 6 ft lengths got reversed as if we had six, 8 ft lengths and four , 6 ft lengths there would be enough for the tasks.
Lastly does Van's ship Flamemaster out to Canada? I seem to remember that was an issue back when I built the RV-10.
Thanks Ron
Hello Support
Thanks Ron
