G-force
Is this typical or did I just get the set made on a bad day? Rudder rod end pivots are screwed in per the plans. Horizontal gap between the VS and rudder counterweight arm is even so I am sure the rudder is straight. I've already filled the VS tip with flox and some fiberglass mat, I'm planning on just sanding it down to be even with the ruder tip. Comments?
![gap.jpg](/proxy.php?image=http%3A%2F%2Fwww.dslextreme.com%2Fusers%2Fmwss%2Fimages%2Fgap.jpg&hash=1af1abb9253aa225a9f01479bbcec909)
