So I finally finished all of the control surfaces and got back to the wing. I put up the wing stand this weekend and even though I haven't straightened flanges or fluted any of the ribs, I wanted to put it together to see it start to take shape. The problem I see is the W-711 seem to be mis-labeled. I started working on the right side because that is what I happened to grab first, even though the drawings show the left wing. For the right, I'm used to seeing parts "reverse" for L and R parts. i.e. the W-712-R for the wingtip of the left wing is a W-712-L for the right wing. This worked to keep the flanges facing the same direction (but mirrored) for the right wing. The problem came to the W-711s. If I did this with them, they would be reverse. I put up the Left spar and found the same thing. Everything matched except the W-711s were reversed from L to R. I assume it's just a L and R mismatch from Vans.
What I assembled matches the drawings so I'm not sure if I'm telling the community or asking a question.
I will say my wings delivered during the biggest part of the delivery issues from Vans and this isn't the first mislabeled part I've found in the kit. ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Maybe I'm just excited to see the wings starting to take shape!
