Hi guys
happy new year! I was actually not sure in which categorie to post this thread as many things are concerned. But as I am building a RV9a, this one might be the right position. I will categorize my questions by DWGs, i guess thats the easiest.
-DWG 4:
E-921 Elevator Gusset, I forgot to build it but now the elevator is done. Is that bad? Plus I also forgot the secure wire. what is it actually for?
-DWG 9:
I have the Pitot Tube for the Dynon with a static point. Do I still need to install the Vans Static Kit?
-DWG 12:
Should I seal the T-407 and T-408 with Tank Sealant?
- DWG 27A:
How exactly did you guys attach the elevators to the elevator horns?
- DWG 35:
U-403-PC Breake Mount Flange, what is it for? I just found it somewhere...
thats it so far.
Im looking very much forward for your replies!
Cheers
Sunit
-DWG 4:
-DWG 9:
-DWG 12:
- DWG 27A:
- DWG 35:
thats it so far.
Cheers
Sunit
