N355DW
Okay, all components of the left wing ended up perfectly aligned in every way, but on the right wing, while the trailing edge of the flap and aileron line up perfectly, the aileron seems to rise at a slight angle as you go outboard in relation to the flap. The string I am holding is straight in relation to the T/E of the flap, and the distance from straight to the outboard T/E of the aileron is about 1/4" to 3/8". I didn't see anything I could really change to fix this, the end edges of both flight surfaces are straight, they just make a slight "vee" at their junction in the middle of the wing.
Will this be a problem?
thanks, Damon
thanks, Damon
![IMG_1954.jpg](/proxy.php?image=http%3A%2F%2Fi1095.photobucket.com%2Falbums%2Fi470%2Fdwack55%2FIMG_1954.jpg&hash=4bcfef1275a4072eae70c493d0c5872b)
