Hi,
Do I have minimum edge distance?
I noticed when fitting right main rib HS-405 between the aft spar HS-603, front spar HS-702 and skin the rib will not get all the way inside the front spar flange.
When I went back to the left 405 rib which is already drilled as in the 1st picture. What should I do with already drilled on and the one yet to be drilled
Regards,
Mohammed
![BJ0QEfTCIAMcm4r.jpg](/proxy.php?image=https%3A%2F%2Fpbs.twimg.com%2Fmedia%2FBJ0QEfTCIAMcm4r.jpg&hash=99e570b5b216f470f0116e1f6375d7c0)
![BJ0SnhDCAAEHFvt.jpg](/proxy.php?image=https%3A%2F%2Fpbs.twimg.com%2Fmedia%2FBJ0SnhDCAAEHFvt.jpg&hash=ab6487b964b1b998767b9da2d99ac910)
![BJ0TWeoCAAAWDqy.jpg](/proxy.php?image=https%3A%2F%2Fpbs.twimg.com%2Fmedia%2FBJ0TWeoCAAAWDqy.jpg&hash=f1ea8edd4f5fbd1816d1314422a0df9a)
Regards,
Mohammed
