Engine broke in but still have almost a case of mineral oil. Can you use mineral oil too long? Pat
P Pat Stewart Well Known Member Nov 1, 2012 #1 Engine broke in but still have almost a case of mineral oil. Can you use mineral oil too long? Pat
mannanj Well Known Member Nov 1, 2012 #2 Mineral I'd use it to top off between changes and throw in a quart or two in with your regular changes unless someone else needs the oil.
Mel Legacy Member Mentor Nov 1, 2012 #3 Like Mannan says, just use it in conjunction with your regular oil. Won't hurt a thing.
rzbill Well Known Member Nov 4, 2012 #5 +1 Thanks. I was curious too and had not gotten around to asking my locals.
mike newall Well Known Member Sponsor Nov 4, 2012 #6 Keep using the mineral oil until it is finished - then switch to multigrade.
S socal Active Member Nov 5, 2012 #7 I still have oil in IO-360 Lyc from when it was shipped, getting ready to start up. Whats the rec oil for break in? Mineral Oil Like what Aeroshell ???
RV10inOz Well Known Member Nov 5, 2012 #8 The oil you want is AEROSHELL 100. When you are done with that use either the Aeroshell W100 Plus or the Aeroshell W 15W-50. My preference is the 15-50
plehrke Well Known Member Patron Nov 5, 2012 #9 Mel said: Like Mannan says, just use it in conjunction with your regular oil. Won't hurt a thing. Click to expand... Do you need to worry about adding Lycoming LW 16702 antiwear additive since Mineral Oil does not have it formulated in?
