Hello all, now I know a gillion of you bought these things and I recently installed them. I used the typical .063 mounting flange.
Now since I've drilled and riveted and installed the studs I notice after adjusting them that there is about only 4 threads of the barrel left inside the receptacle. MilSpec sent me #3 Studs like I'm sure everyone else got. Does anyone think this is bad? It sure seems like it would be better if the entire barrel was inside the receptacle.
It seems like it would be better if the studs were shorter and or the inside of the Cowling was built up with a few layers of glass and then installing the shim between the CamLoc flange and the firewall flange like Vans tells you to. The other fix would be to add a spacer on the underside of the CamLoc flange just the opposite location of what MilSpec shows on page 4 their instructions. How did the install of other folks go? Post some pics of your flange and receptacle after the adjustment was made. I'd like to see how others peoples came out.
-Jeff
![COWLING%20044.jpg](/proxy.php?image=http%3A%2F%2Fwww.jeffsrv-7a.com%2FCOWLING%2FCOWLING%2520044.jpg&hash=7a111b0d4451b4c08c9e00d525b480fb)
![COWLING%20129.jpg](/proxy.php?image=http%3A%2F%2Fwww.jeffsrv-7a.com%2FCOWLING%2FCOWLING%2520129.jpg&hash=6bca329c603050293e31ff2afe8874f2)
-Jeff
