FireMedic_2009
I'm looking a multi-pin connector for my stick. I have an Infinity grip and is currently wired without a connector. My guess is there are 8 - 12 wires. A couple of 4 or 6 pin connectors would be great so I can pull the stick off the co-pilot side so I can work under the panel easier. Obviously the connector would have to be able to slip through the control column tube where the stick attaches to. I could use d-sub pins and heat shrink each pin connection but it would be a pain to cut the heat shrink off each time I have to remove the stick and then re-heat shrink the pins again. If I use a spade connectors I would have to stagger the connector in order to slip through the control column.
Or do I drill a hole in the stick above the bolt and run the wire out and just use a sub-d connector?
Thanks for your input and ideas
