MGL XTreme EFIS update
Rainier Lamers
Just a heads up for those waiting for the XTreme autopilot integration. An update of the firmware has just been posted.
This enables enough of the autopilot functionality to be able to install and test the servos. The core of the autopilot (the actual executive) will be enabled after all flight testing has been completed.
Rainier
CEO MGL Avionics
XTreme-EFIS Version 1.30 firmware is available for download from www.mglavionics.co.za. Please remember to save your settings, LOAD DEFAULT SETTINGS and then restore your settings.
Main upgrades are Auto-Pilot Servo setup and testing, SP6 In-Flight calibration support.
Enhancement: Added in the 2 axis autopilot menus and preflight checks (Servo checks are enabled)
Enhancement: Added in support for the new auto calibrating SP6 compass
Enhancement: Redone the current calibration menu option and calculations
Bug: Fixed the G-Force not going negative when using the SP7 with the CAN protocol
Enhancement: Added a "current" setting to the altitude bug and heading bug selection
Enhancement: Updated the magnetic variation tables
Enhancement: Added the slip indicator if a SP6 has been connected and no attitude sensor is present
