gerrychuck
My local avionics guy installed a new MGL V6 for me last week, and my first opportunity to use it was today. Unfortunately, all did not go well. I use an ANR retrofitted (Headsets Inc kit) HGU 55 helmet, and although I was able to transmit and receive through it, I couldn't get enough volume to be able to understand transmissions or hear sidetone well enough to try flying with it, although I could hear well enough (barely) on the ground with the engine off. Tried one of my Lightspeed ANR headsets, and it was marginally better, so I tried flying with it, but volume was nowhere near enough to be able to understand what was being said to me. Later, in the hangar, I tried a DC H.10.30 set, which was no better. With all headsets/helmet, transmissions to the unicom base 500 yards away were received 5x5, but my hangar renter reported hearing me call when backtracking on the runway (he was inbound) and said that transmit quality was poor. Talked to my avionics guy, and he suspects the d-sub connector behind the radio is not mating properly, which he was concerned prior to this and was planning on replacing before I fly to OSH this weekend.
So...while my tech is troubleshooting, is there anything in the setup menus that I am missing here? There are mic level adjustments, but I don't see anything with regard to volume, aside from the obvious - the volume knob on the unit.
Gotta get this fixed this week, or my first trip to OSH is off Any ideas or insights appreciated.
On a related note, I was trying out my Vertex handheld tonight, with the headset adapter I bought for it. Very low volume on receive and no response to transmitted radio checks using either the helmet or the Lightspeed headset, with excellent volume and no problem with transmit using the radio in its
"bare" mode without the headsets. Tried my trusty David Clarks, and they worked perfectly through the handheld. Tried changing to new batteries for the helmet and Lightspeed with no change in performance. Then I tried my OTHER, identical Lightspeed set, which worked as well as the David Clarks! Tried going back and forth a few times, with the same results; one Lightspeed set works perfectly, as well as the David Clark passive set, and the other Lightspeed set works very poorly, as does the helmet. I really don't get this...
