Thanks for the update when I checked last week on lead time it appeared you might be out of stock for several weeks on the V6...? Also is there an easy way to wire an external speaker? Just asking in your plane did you go with one or two comm radios? If you went with 2 how did you switch between them?? Thanks,
The first batch went faster than expected, much faster - the last of the lot where put in a box today and are going off to the U.S.
We are pressing hard for the next batch to come off the line so hopefully it will not be long.
Wiring up two radios is easy.
Depends a little on what you want to do. If you want a full redundancy radio (i.e. TX on COM 2) - this is what I would do:
Headphones:
Each radio has two stereo outputs - one for pilot and one for the pax circuit. I would join these betwen the two radios but route COM2 through a 4 pole switch on the panel so I can kill the audio from COM 2 if needed.
All of the outputs from the two radios each (left+right) go through a 10 ohm resistor so the outputs do not short each other.
OK, that is simple. Now for the MIC/PTT.
I would use a second multipole panel switch on the MICs. Use the switch to connect the MICs either to COM 1 or COM 2 - at the same time also switch one or both PTT inputs (as you need). Switching the MICs has the advantage that a radio that is powered down will not load the microphones which could cause distortion or low audio depending on your headset type.
So, two switches on the panel - one to "kill" audio from COM 2 is needed and another to switch TX between COM 1 and COM 2.
Call it a "poor mans" audio panel - but it does all you need.
Stereo music can be routed to both, as can EFIS as well as mobile phone as all of these can be enabled in the radio so if you need to switch these (if your COM 1 is U/S) you do that in the menus.
Make sure you use proper shielded cables and apply the shields correctly (shield connected only on the radio side at one point). At least shield the microphone cables - headset is not that critical.
Use microphone inputs 1,2,3 and 4 depending on how many circuits you need and then assign them in the menu to pilot and Pax (for example 1 pilot, 3 pax).
The radio has a "isoltate" pin on the connector - wire a panel switch to ground to "isolate" pilot and pax intercom circuit. I.e. if you activate the switch your pax can talk to each other without the pilot hearing the conversation. If you have assigned 2 pilot and 2 pax, the pilots can talk to each other and the pax can talk to each other (all can listen to music).
Deactivate the switch and everybody can talk to everybody.
Also choose to use 1 or 2 PTT inputs. You might want a PTT on the pax side. You can also decide how this is to work (i.e. if any PTT is pressed, should the voice from the "other" circuit be allowed in the transmission or is it blocked ?).
It's pretty flexible but you can keep it very simple as well.
Rainier
CEO MGL Avionics
