MGL V10 Mounting
Lionclaw
Has anyone installed a V10 yet? I'm looking for info on the mounting hardware. The holes don't appear to be countersunk. Are people using button screws? I'd like to use socket cap screws, but the heads will stick out too far. Is there enough material there to do a cylindrical countersink?
Lots of questions... ;)
The housing are intended to be fitted with sockethead screws.
There is a bit of "meat" in the housing so you can countersink or drill the holes out a bit to sink the socketheads a few mm.
Rainier
CEO MGL Avionics
