Merge LOG files for Saavy
h&jeuropa
I've been unsuccessful getting Saavy to recognize my merged zip file. It only displays the last LOG file. I checked the zip file and it has the 3 LOG files I merged.
Anyone used this feature successfully?
Jim Butcher
It works for me. I just merged my log files from a flight this weekend last night. I did learn early on that the name has to be correct... grt-merge-xxxx.zip You have to rename the .zip file to that format. Also, only merge .log files that are in a sequence.
Thanks for the reply.
Did you just make the zip file and then use the Add New Flight to upload it? Just drag the zip file?
Jim Butcher
one thing
The first file of the merge needs to be the first file of a series recorded. ie, it is not a -1, -2, etc file.
Merrill
Yes, just drag the zip file over... it processes for a bit, let's you know if it was successful, then you can view it.
