bret
So this question is in regards to the epoxy primer to the base color of a BC paint system. what is the maximum time for the best adhesion, I was told that if I block sand the primer, there is no timeline for applying the base coat, (mechanical) or the time line of shooting primer, sand, and then the base coat for a chemical and mechanical crosslink? I would like to primer, sand, then do the paint scheme moc up over a week or two, then paint the plane. I know you need to do the base and clear within a short time, but what about the primer to base? what say Ye paint experts?
