I have an RV-3 I'm restoring and I'm planning on flying it with just a facet electric fuel pump. My question is: Is there anyone else out there running with just an electric pump, and a fuselage mounted fuel tank? If so, I'd be curious to know if it gravity feeds okay at full power, and at VX type speeds / angle of attack...
I plan on verifying that mine will flow sufficient fuel during the testing phase while at a safe altitude over the airport. If this fails then I'll go ahead and put a mechanical pump on it...
Thanks for any info...
Doug
RV-3 Restoration nearing the end!
Doug
