yankee-flyer
I KNOW that somewhere in the instructions there was something on measuring the wheel toe-in with thread and it gave what the measurements should be but I'll be darned if I can find it. Someone with better memory, help? Measuring from center of the tire to center of the tire, I get about 1/2" wider at the rear of the tire than at the front.
When I replace the tires (as soon as Desser makes some) I'm considering putting a thin washer under the bottom rear mounting bolt (between the gear leg and the axle mount) and a standard one at the front to reduce both camber and toe-in. My concern id that the axle plate will no longer be in contact with the gear leg I'll put undue loads on the bolts. Scott can you weigh in (unoficially, of course)?
Wayne 120241/143WM
Wayne 120241/143WM
