rjcthree
If it's possible, I need a quick measurement. Basically, wings need to be bolted in, and side covers (vertical covers for the F-904 uprights, blind riveted) need to be in place. A finished airplane works.
I need the dimension of the lower point of the side cover the part that angles down) to the top of the wing spar. It should be in the neighborhood of 5/16".
It's my hope I can armor the pitot/static lines (using air brake synflex for pitot static aoa lines) and run up that section in to the panel. It would clean up my wiring install immensely.
Thanks in advance, Rick 90432
