yankee-flyer
I think I have problems. Started the C.I yesterday and checked the ELT. G-switch test was fine, and the functional test also gave the sweep tones. But when I switched back to "Arm" instead of one flash of the light I got three flashes, then 4 more. A second check of the G-switch (not connected to the airplane) still gave the sweep tones but then the light on the ELT flashed 3 times, then 4. Battery is good until 2021. Anyone else run into this?
Wayne 120241/143WM
Wayne 120241/143WM
