Phil
For those of you who will be working on the McMaster Carr door seals in the future, here is a tip that you can use on your RV-10 doors.
Depending on the McMaster seal that you purchase, you will need either 3/16" or 1/4" grip thickness. In my case I'm using the 1/4" grip.
When the time comes for you to finish the cabin top, you will want an even 1/4" thickness all the way around the door opening for the seal to grip on to. That usually requires adding some glass and filler on the inside of the door and then sanding it back off to 1/4".
Here is the short cut. Fill it with glass and filler, then rig up one of these and shim it so that you get the perfect gap. In my case it's 1/4". It makes quick work of an otherwise no-so-fun task.
Someone might have some up with this before, but I thought I'd share anyway because it'll be new to somebody and it'll save somebody a few hours of sanding and filling and sanding and filling...
Phil
Phil
