I know the max baggage is 100lbs. I'm looking for a Maximum Passenger Load. I cannot find it published anywhere. I don't even know what the definition of Maximum Passenger Load is.
This does not apply to passenger areas that are beside the pilot as is the case for the side-by-side models like your 14. The tandem and 4 place planes would publish an arm for the rear passenger station, no idea if that would contain a weight limit.in any area of an aircraft designated for the carriage of passengers, other than an area beside the pilot, a placard showing the maximum permissible load for that compartment or area:
MAXIMUM PASSENGER AND/OR BAGGAGE LOAD: ..............KG (LB)
My local inspector is asking for it. Not looking to debate the requirement. Looking for what number one would use.
